Need help with roaming data
I have a blackberry curve and will be using the 3 day texting add-on when I travel to the US, I know I have to leave my network on to send and receive texts but how do I get on Wi-Fi but not get charged for leaving my data on? If I turn off roaming data will Wi-Fi still work?
Yes turn off data or roaming data! And wifi will still work with data turned off and roaming data turned off
While connected to Wi-Fi, Mobile Data isn't used. Once you get off Wi-Fi though if Mobile Data is off you won't get any Data connection, though SMS/Calls will still work.
