n0 data when out of wi.fi range , how do i activate on the road reception?
  • 7 March 2021
  • 1 reply
  • 17 views
o
1 reply
Does your plan include data?
In order to use data when out of Wi-Fi range, you will need a rate plan that includes mobile data. If you have a rate plan that includes data, it’s just a matter of turning on mobile data on your phone.
Which Blackberry do you have?
For Blackberry, (I’m using a BB Key2 LE) go to Settings > Network & Internet - select Data usage. Under Usage and next to Cellular data, slide the toggle switch to the ‘on’ position to enable data.
Note: If you do not have a data plan and you enable mobile data on your phone, you will be charged a pay-per-use rate of $13/100MB.
