My BlacKBerry Curve 9320 won't turn on.
I've never had any problems with the phone, and I've had it for about 4 months. Then recently, all of a sudden it shuts off and won't turn on again. I've tried charging it, and all that happens is the screen backlight appears to turn on, and sometimes the red light will show for a minute. What can I do to fix this?
Well, if you only had the phone for 4 months then it should still be under warranty. Sounds like there something more serious than anyone of here could recommend to fix. Take it to a koodo store and they will send it away for repair. As long as their is no water damage the repair is free. It could also be your battery that for some reason doesn't hold the charge. You can easily find that out at a koodo store.
If you are with future shop (or other store) They have a protect plan and if you take it they should repair it or replace it
