Long Distance Plans
  • 22 September 2018
  • 451 views
Can I get a temporary long distance plan while travelling in England between Oct. 4 & Oct. 15, 2018?
There is easy roam available as an option for 12 dollars a day that let's you use your plan as per normal. You'll be able to call back to Canada and to UK numbers.
Ipersonally suggest getting s Vodafone or something similar sim card. They have a prepaid "pay as you go 0" plan for one pound a day that gets you unlimited talk, text, and 500MB of data for 24 hours for example. It's much cheaper.
Well thanks for your prompt, comprehensive reply. Where do I purchase a "Vodafone or similar sim card"? Thank you in advance for your response.
Theres Vodafone shops all over the UK. If memory serves you can buy them at most airports as well.
Thank you, Goran!
This wiki should help
http://prepaid-data-sim-card.wikia.com/wiki/United_Kingdom
But once you made a decision of what you want, you can go to the carrier's website for more details/locations
