Koodo phone will not take Koodo sim card
  • 14 November 2014
  • 3 replies
  • 25 views
i bought a prepaid sim for a blackberry i bought, when i put the sim in and turn on the phone, theres a message up on the top of the screen that says its not allowed. I'm not sure what the issue is
Did you get the phone from Koodo? Is it saying invalid SIM? Check to make sure of 3 things; 1. Make sure your phone is unlocked 2. Check that your phone is compatible with koodo: http://help.koodomobile.com/getting-started-with-koodo/sim-cards-and-non-koodo-phones/how-do-i-know-if-my-phone-will-work-on-the-koodo-network 3. That your prepaid SIM has been activated.
Not Allowed could also mean the devicr is banned on the network. What BlackBerry do you have?
