I own a Blackberry Z10 phone right now and my wife wants it, so now i'm interested in a I-phone Does anybody have any favorites Model #?
  • 28 September 2013
  • 7 views
(empty)
iPhone 5s
do you have one?
Hey David, You can click here: http://koo.do/PD9yga and then on "More info" to check the specs for each iPhone. Your best bet is to visit a Koodo Store nearby (http://koo.do/IVOQTV) and talk with a rep, you will be able to decide which iPhone is the best for you 🙂
The iPhone 5s is a solid option as it simply flies through iOS 7 however if you dont need the newest and greatest i'd also recommend an iPhone 5. I personally prefer iphones due to build quality, ease of use, and reliability. If you prefer android S4 is great as it has a wide angle display. Hope that helped! 🙂
oh i dint see the iphone caption. 16gb 5s should be good but if you have a large music library and want them on your phone then the 32gb is worth considering however 32 is quite expensive. so i suggest 16 if you dont need lots of space
