I just activated my SIM card, how long should I wait before inserting it and attempt to unlock my phone?
  • 30 June 2016
  • 2 replies
  • 48 views
Using the SIM card to unlock a phone
Userlevel 4
If the sim is activated,  you are ready to insert it into a phone.
Sounds like your phone is locked, so at startup, it will ask for the unlock code
Just to add, a sim card does not even need to be active to unlock a phone. It need only be from a provider other than the one it's locked to.
