i have lost my blackberry and have been given a i phone can i put it on my plan and how much will it cost
what plan do you currently have? You'll need a new sim card, which is $10 for postpaid and $20 for prepaid. Any other charges that you may incur depend on the current plan and what features you're using.
Did you report your phone was lost? Call Koodo at 1-866-995-6636 from a land line to making sure that no one will be able to use it.
The you will need to have a Telus or Koodo iphone or the iPhone will have to be unlocked for it to work with Koodo. You should be to put your current plan on it. However if was an older BB plan note that data on an BB is different that data on an iPhone and will result in additional charges if you attempt to use data.
Dennis wrote:
The you will need to have a Telus or Koodo iphone or the iPhone will have to be unlocked for it t...
Blackberry plans work just the same on other devices but blackberry specific add-ons won't transfer over and should be removed from your account. It doesn't work the other way though, other phones (iPhone, android) data plans will not work with legacy blackberry phones.
