How do I upgrade my BB Curve 9320 to BB OS 7.1?
  • 31 December 2014
  • 1 reply
  • 29 views
I see that Koodo is offering pre-Owned Curve 9320s with v7.1. I have an older one with OS 6.0.0 thx
Best answer by Matthew 31 December 2014, 22:17
Go to options > Device > Software Updates. If that doesn't come up with anything you can go to www.blackberry.com/update and download it to your computer, then connect your blackberry to the computer and install it that way
1 reply
Userlevel 4
