How do I transfer from Rogers on BB curve? Is new phone required?
  • 22 May 2015
  • 3 replies
  • 280 views
(empty)
That depends on whether or not your BB Curve is unlocked or not. If it's locked you can have Rogers unlock it for you before you leave for $50 or you would have to get a new device. NOTE: Don't cancel with Rogers before going to Koodo. You'll likely be able to keep your phone number by doing a number port. (Which will cancel your Rogers account for you)
That depends on whether or not your BB Curve is unlocked or not. If it's locked you can have ...Koodo can also unlock it for you on Activation for 35$. There are also several sites that will unlock these older BB for free. What model of bold do you have, it's usually a digit number that starts with 8 or 9
Userlevel 4
That depends on whether or not your BB Curve is unlocked or not. If it's locked you can have ...Some sites like freemyblackberry can unlock for free if you are willing to wait a few days. Like others have said, don't cancel with Rogers as you will lose your number
