help using canada wide talk + text pay per use data add on
my plan is the Canada-Wide Talk + Text 25 Dbl so im supposed to have the pay per use data add on, but when i turn on data services my blackberry curve tells me browsing over the cellular network is not included as part of my current service plan. any ideas of how i can start browsing the internet besides wifi?
Hi Eli,
Josh765 wrote:
Hi Eli,
hi, any ideas?
Josh765 wrote:
Hi Eli,
Hi Eli, The new Canada-Wide plans, like your Canada-Wide Talk + Text 25 Dbl requires you to have an additional add-on (called Data Saver Blackberry Access) if you want to access data with an older Blackberry such as the Curve you mentioned. Don't worry this add-on does not have an additional cost 🙂
Josh765 wrote:
Hi Eli,
oh great! thanks very much for the help!
