help me
I already have a blackberry with koodo but I buy a unlock iphones. can keep the same plan itself + / - $ 35 thank you
Yeah, you're not required to change your plan if you change your phone. Blackberry to non-Blackberry can sometimes be a bit tricky though, with the potential of the social networking add-on that's only compatible with Blackberries. What plan do you have?
Go to Self Serve and click the Change Mobile Phone and change your phone. You may need to get a new sim card depending on the model of the Blackberry and the iPhone. Once that is all set up, you are good. However, if you have a Blackberry specific plan then those services will not cross over to your iPhone so you'll be wasting money. Make sure to get rid of any BB add-ons that you don't need anymore.
