hard ware up grad
[b]Do I need new sim card and so on for a new device or used? thanks Looking on ebay for Blackberry if they work on prepaid:
Any phone works the same prepaid or postpaid. You do. It need a new Sim card. You only will need one of its the wrong size. But you can buy adapter to go bigger or you can get it stamp cut or newer ones are perforated so they can be snapped into the size you need. Make sure to find out if the Sim card will be the same size
Thanks
Heads up: A blackberry 10 or blackberry Android device will work on prepaid. But the legacy Blackberry may have problems getting data.
Heads up: A blackberry 10 or blackberry Android device will work on prepaid. But the legacy Bla...Thanks
