Exchanging Phones but keeping current plan
I am currently using the Blackberry Curve (with zero balance on the tab) and I would like to exchnage it to the Samsung Galaxy Mega (and put it on a tab) but I would ike to keep my existing plan minus the BBM. Is this posible? Or do I have to sign up to a new plan?
Depends on which tab you want to use. Tab S can be used with any plan, regardless of price. Tab M can be used with any plan $30 or more. Tab L can only be used with Tab L plans.
Userlevel 2
Hi there! As Timo said it depends on the Tab you’ll use. Since you’re switching from a Blackberry to an Android you may have to change your plan as the Blackberry Curve uses a different data platform than Android. We’ll be able to give the exact answer if you send us an email (via Self Serve) http://koo.do/YqucV0. You can also visit a Koodo store: http://koo.do/IX6h7U. Thank you. ________________________ If you see a good answer, give it a star.
