Can't connect to China carriers with my Blackberry Motion (BBD100-2)
  • 13 October 2018
  • 4 replies
  • 464 views
I travelled to Shenzhen in August 2018. My Blackberry Motion phone got roaming signal from Hong Kong phone carriers when I was in HKG airport and even in Shenzhen when I was closed to the Hong Kong border. But I cannot connect to any of the China carriers when I was a bit further in land.
Has anyone experience similar problem?
Best answer by BobTheElectrician 13 October 2018, 13:16
Fast check site: www.willmyphonework.net
A little more detailed: https://www.frequencycheck.com/countries
Did you check willmyphonework.net to see if your specific model would work with Chinese carriers?
Did you try China unicom? According to the pdf list here, it's the only carrier that you can roam with:
https://www.koodomobile.com/help/easy-roam
Back in June 2018 when I was in Shenzhen, I had my Koodo line with a Moto G5 phone (different SIM card though). I had no problem with the roaming. I even got the easy roaming charge for 3 days from accidentally placing calls.
Did you try unicom this time?
