Blackberry z10 wont turn on
  • 26 November 2014
  • 280 views
my phone wont turn on, i left it charging for 3 hours and still wouldnt do anything and then left the battery out for 4 hours, what should I do?
Have you tried a different charger and outlet?
yes
yesIf you charger and outlet are working then the next guess is that there maybe an issue with your charging port on your phone.
If you've had it for less than a year, I'd suggest taking it in for a warranty claim. Do you know any other people with a Z10? If so, could you pop in their charged battery into your phone to see if it turn on?
I am having similar issues. phone shut down by itself. Now it is indicating that the battery is dead even when plugged in. I have tried different chargers and outlets and removed and reinstalled the battery. Nothing works. Phone is over a year old.
