Blackberry Z10 bbm problem
  • 13 September 2013
  • 1 reply
  • 19 views
I have a blackberry z10 and for some months now my bbm has been acting up. My profile picture refuse to change. Please does anyone know how i can fix that ?
Best answer by Chad Burr 13 September 2013, 20:04
BlackBerry is aware of this issue and is working on correcting it. http://www.blackberry.com/btsc/KB34849 The workaround unfortunatly is to Wipe your device and then relogin to BBM. However. I would recommend you join the beta program and use BBM Beta versions. This will replace your current BBM with the beta version and may solve your problem. If you do decide to try the workaround mentioned in the link I recomend using BlackBerry link to do a Partial Backup (Backup your App Data and Settings and media into three different backups. Only restore your app data and not your settings or media. IF it doesn't resolve your problem then restore you settings and media. WARNING: YOULL LOOSE INFORMATION ON YOUR BB like texts and emails. so if they arent in the cloud somewhere then poof they are gone.
1 reply
