Blackberry Q5- Does it connect to wifi easily, don't need a data plan?
Userlevel 3
I'm considering buying this phone outright. I wanted to know if this phone will connect to wifi (home, public wifi etc) without needing a data plan? I know the old blackberries you needed a data plan to hook up to wifi or something like that. Basically I don't need data. I really want to use this phone for talk, text and wifi at home or in public to check map, bus schedule etc. Any problems with connectivity? I have a Linksys router at home. Thanks!
Yes it will
Userlevel 4
To clarify, Yes, it will work with Wifi without a Data plan. BB10 is just like ios/android in terms of data.
Userlevel 3
Thank you! 🙂
