Blackberry Automatically shutting down problem
I am using Z10 since 2 months. OS Version - 10.2.1.2977 After fully charging the device, when the battery level drops to 65-66%, the phone shuts down automatically. It does not start up by pressing the power button. To start the device, I have to connect it to the charger. Then to use it, I have to again charge the device to 100%. I performed a factory reset by using blackberry link software on my pc but no solution. The problem persists. What seems to be the problem?
Sounds like the battery needs replacing. You can pick up cheap OEM ones off Amazon or eBay
Hi Saptarshi, if it's a battery issue and your phone is still under warranty, we can actually exchange it. The best is to call us first at *611 or 1-866-995-6636 from another phone, option #6. Thank you! ________________________ If you see a good answer, give it a star.
Yannick wrote:
Hi Saptarshi, if it's a battery issue and your phone is still under warranty, we can actually exc...
I had bought the blackberry Z10 2 months ago from ebay......this product has seller warranty only for software issues. 😞
Sorry to hear that, Saptarshi 😞 Hopefully you can find one on Ebay or Amazon , as per Jonathan's advice!
