Blackberry 10 (Z10) require Blackberry data plan (BIS plan)?
  • 1 February 2013
  • 3 replies
  • 13 views
Userlevel 4
I can't seem to find a firm answer on this topic online. Back in October, sources said yes. Yet, in the last few days, sources say no. I currently have the Super 6GB (summer 2012) on a generic (android/iphone/windows) plan. If I pick up a Z10, do I need to switch to a current market plan, or will the Z10 work with my 'generic' data plan?
You wont need a BB compatible(BIS) plan with BB10. A regular smartphone plan will work. So yes, it will work with your generic data plan
Userlevel 4
Thanks Ahmad. Just to triple check, even BBM will work?
Thanks Ahmad. Just to triple check, even BBM will work?yes everything BlackBerry is known for will work 🙂
