$30 plan + BlackBerry - will that data work on it or do I -need- an add-on?
  • 10 December 2012
  • 3 replies
  • 26 views
If I get the $30/month promotional plan with 200mb of Data - if I have a BlackBerry - I can still use the browser on it and the GPS, without having the BlackBerry-specific data plan? Or would I still need the blackberry plan?
Userlevel 3
Hi RC Yes you can get that plan and use the data on the BB without a BB specific add-on
Just make sure to select blackberry plans from the dropdown menu when you change your plan.
@ RC: It will work without problem, the same plan is available for BB phones, so no need of additional addons.
