Incorrect data roaming charged
I live on an island that borders the USA, when I go to certain beaches it connects with the USA towers and charges me Easy Roam even though I’m still in Canada.
I have data roaming turned off on my phone and it still happens.
How can I remove these charges and permanently disable Easy Roam?
Let me flag a rep for you.
A better method to prevent accidental roaming would be to set your Network from Automatic to Manual and then select Koodo.
Good suggestion, thank you!
Hi @BethanyCouture
If you notice a  charge once your next bill is posted, please start a new post and we will look into it.
Feel free to follow the steps in the article provided by @Dennis above, this should prevent further accidental roaming charges.
