i have tried over and over to get a rep to reverse a roaming charge but have had no luck ......is there not a way to talk to one by phone ????
  • 21 September 2022
  • 2 replies
  • 26 views
on August 18 I was charged for roaming in the USA ….I was not in the USA ...I was in Point Edward Canada….I need $10.00 refund on my bill
We can flag a rep for you if you wish - that’s probably the fastest way to sort it. Meanwhile, make sure you turn off roaming while in Canada to avoid accidental roaming fees.
Hi there, @wilco . We have looked into your account and applied the necessary adjustments. You can see the changes updated in your Self serve.
Cheers, :)
