Billing issue
  • 23 September 2022
  • 4 replies
  • 43 views
Even though I have an unlimited Canada plan my last bill showed airtime charges.  Why is this?
Best answer by Mayumi 23 September 2022, 18:14
Did you check page 3 etc on your invoice to see details on the charge?
Did you change your plan recently?
The number you got charged was Canadian number or International/US number?
i checked- I had call forwarding on.  $0.60 every time a call was forwarded.
They have an Add-on for “ call forward “
If you use it often, then you should consider to add it.
https://www.koodomobile.com/en/help/call-forwarding?search_api_views_article_search_fulltext=Call%20forward
