will a cat b15 work with koodo?
  • 8 September 2013
  • 3 replies
  • 11 views
2G GSM 850 / 900 / 1800 / 1900, 3G 850/1900 is the networks it suports will i be able to use it if its unlocked?
It should, its 3G bands are 850/1900, so in theory, it should work if unlocked! 🙂
Be sure to setup Koodo's APN--> http://koodomobile.com/en/on/switch2koodo-step-3-c.shtml
Nice phone! Follow the link below to determine if the device is compatible with Koodo's network. Dial *#06# from your phones' dial pad to get the IMEI number. http://koodomobile.com/en/on/switch2koodo-step-1-c.shtml
