WiFi Calling Charges
  • 9 May 2019
  • 4 replies
  • 370 views
Hello, I am using monthly plan with below add-on bundles:
"1000 Intl LD min Bonus V2"
Now I just need to know if I enable WiFi calling, will there be any additional charges if I made calls to following countries which are included in the ad-on ( " India, Germany, China, Hong Kong, Bangladesh, Italy, Mexico, Australia & Taiwan" ?
Best answer by Dinh 9 May 2019, 18:41
Wi-fi calling tech is to help the phone to reroute call/text through wifi to a Koodo server. All of your phone calls, texts are still calculated as normal minutes.
So if you had the add-onm your calls to those countries are calculated similarly as normal calls without Wifi calling.
With wifi calling, you will still incur the use of the LD minutes.
is wifi calling automatically included in the plan, free of charge? I enabled wifi calling on my iphone but i am just wondering if there will be additional fees associated with this service.
Checked my plan it says Koodo VoLTE Access is included - does that mean Wifi calling is included as well?
Thanks.
Thanks.
@HankL you need a supported Koodo device to have wifi calling. If your device is supported, you can simply enable (activate) it in your phone. Detail instruction is here https://www.koodomobile.com/help/wifi-calling
