When is best to change your plan?
I need to go up to the next level plan because I'm close to 500 mb data and have another 3 days till the billing cycle end (only 15 mb left for me). Should I wait till the last day or is there a better way?
Best answer by Sophia 11 April 2015, 20:24
If you see a plan you want, I'd recommend you change now, Ronni. The 3 days will be prorated anyway, so no harm done. And how knows - plans can change any second and you may lose out on the one you want...
1 reply
