Unlocked Nexus 4 Compatible with Lightweight Canada-Wide Plan?
I have an unlocked Nexus 4 and thinking of bringing it over to Koodo. I noticed they have the BYOD 10% discount. Will I be able to get the lightweight canada-wide plans for my device, coupled with the 10% discount? Thanks,
You can get that discount with any plan.
Yes you can!
Ah okay, Thanks. Also, would I be able to get the lightweight canada-wide plan on my device or do I need to go on a Tab Medium plan (+$5)?
Ah okay, Thanks. Also, would I be able to get the lightweight canada-wide plan on my device or do...A tab is a phone subsidy. If you are bringing your phone over, then you can choose any plan and not pay any tab charge. If You get the 10% BYOD discount in lieu of getting Tab credits to use toward a future phone
