Unlimited Incoming Calls Questions
I have a question about the Unlimited Incoming Calls on some of the Canada Wide plans. If you are outside your local calling area do you still get Unlimited Incoming or are there long distance charges when someone calls you? As well, if you are on a plan with a set number of Anytime Minutes, do incoming calls received during the day use your Anytime Minutes if you have Unlimited Incoming?
Best answer by Curtules 3 May 2013, 14:20
Canada Wide plans have unlimited Canadian long distance, so no matter where you are in Canada there will be no long distance charges for incoming calls. Also, unlimited incoming calls mean exactly that, incoming calls will not count toward your minutes, only outgoing calls.
1 reply
