U.S. ROAMING ADD-ON QUESTION
  • 18 July 2014
  • 1 reply
  • 37 views
When buying a U.S. travelling package, if I have relatives phoning or texting from Canada do they get charged long distance fees? also do they receive long distance charges if I phone or text them from the U.S.?
Best answer by Camilo_A 18 July 2014, 14:54
Hi there... If they have a Canada Wide plan, they can call any Canadian number, so even if you are in the USA, they will not be charged when they call you, only the person in the USA will be charged accordingly... And when you call them, as long as they are in Canada, they will not be charged for LD charges, they will be billed according to their plan (minutes, Canada Wide, etc)
1 reply
