Traveling plan not working - do I need a specific setting on my phone for it to work?
Hi there, I called Koodo and asked to be switched to a little travel plan because I'm on vacation in the states from Canada. They said it was enabled when I called, but now it doesn't seem to be working.. is there something I need to set on my phone for this to work?
What do you mean it's not working? The US add-on is only to reduce your roaming charge but you can automatically roam when you enter the US.
Where are you located in the USA? What phone do you have?
my son is having the same problem, Samsung SIII, he has enabled roaming but cant make calls. I have called him succesfully
We might be of more assistance if the questions posed were answered. Thanks
Settings->more networks->mobile networks->network operators Search networks Select either AT&T or T-mobile.
