Stop connecting after limited minutes
Is there any way after completed limited minutes for the month during day time when incoming and out going charged, stop connecting any call? Please reply, thanks
No, there is no way to block your phone from making/receiving calls after you have reached your allotted daytime minutes.
Userlevel 3
You can forward all incoming calls to voicemail. Depending on your phone, you might also be able to disable all outgoing calls. You have to do it manually. It won't happen automatically when you use all of your minutes.
Thanks NOOB & Mobile Master.
