Roaming in Brazil: is it possible? How much does it cost?
Hey Nevair, Unfortunately Koodo doesn't offer any roaming packages to Brazil at the moment so you would have to pay pay-per-use charges. $2.50/min, $10/MB and $0.60 per text sent.
Ahmad wrote:
Hey Nevair, Unfortunately Koodo doesn't offer any roaming packages to Brazil at the moment so ...
To add since I can't edit anymore: If you want to roam while in brazil, you need to add the follow FREE add-ons (makes your phone work): Pay Per Use Intl Long Distance International Voice Roaming International Voice Roaming Which you can add via self-serve
according to: http://help.koodomobile.com/coverage-long-distance-and-travelling/travelling For travelling anywhere in Central and South America south of Mexico: (edited for clarity) voice rate $2.50 CAD per minute Data rate is $10 CAD per MB. texts will cost you $0.60 CAD per message.
