Roaming charges and easy roam bill issue
  • 16 June 2019
  • 2 replies
  • 99 views
Hi everyone;
I am writing here to hopefully have someone understand my situation and help me out as I have had no luck over the phones;
I was out to Dominican Republic, as I do not usually require the network while on vacation. I ran into a scenario where I had to activate the Roaming to use my phone, so Koodo makes this a bit tricky during setup as they ask you to reply 'ADD' to activate roaming and advertise that you will be paying $8/day in the Usa and $12/day in other countries.
I had replied ADD and i began being charged per MB, so I went online and tried to access self serve to see if there is a way to enable the $12/day plan, while continuing to do this i kept getting charged for data and had to keep accepting as I wanted my phone for emergency as I had left the resort.
I gave up logging in and out of my online self serve account and went back to the texts and realized I had to Reply " TRAVEL" to add the second option of the $12/day. At this point im already $170+ in data usage in just a short time from loading up websites and minor usage.
I am not able to explain my situation to anyone over the phone as some of the english dialect with the south american reps is hard to comprehend, I tried the french line in Canada but he was only reading what the previous rep wrote and just shut down anything i was trying to explain.
Hopefully I can find someone that is willing to understand the cluster i was stuck in regardless if Koodo sends a text message or not briefly explaining direction in 2 different text messages , not all customers are aware of the exact process especially during certain scenarios.
If Koodo could track my usage that day, it is obvious I was trying to log into the website and activate the roaming use but was confused and misunderstood why i was not getting the daily rate of $12/day.
Thank so much;
Hi
Where did you see the ADD text? Easyroam requires user to text ROAM to 7626 https://www.koodomobile.com/easyroam
As it is a dispute about the bill/charge, and you have issue with verbal communication, I would suggest you try to send message to their facebook https://www.facebook.com/Koodo. From there you could chat with an agent.
May not be helpful now but Koodo doesnt charge for data usage to access self serve so even though they will send you a message saying you've used your data and here are options to purchase more, you can continue to use self serve without having to buy extra.
