roaming and long distance
i travel a lot for work and i need to call my kids at night currently is putting my virgin bill through the roof do you guys have roaming and long distance plans for this im always within new Brunswick/ Quebec area
Userlevel 4
If you have a Canada Wide plan, you do not have to worry about long distance. There is no roaming in Canada with Koodo. All of Koodo's plans are Canada Wide with the exception of the Iphone plans (I do not recommend) https://shop.koodomobile.com/plans/plans/index.html
If you're travelling in Canada, all the plans are canada-wide, so there are never long-distance charges within canada. And if you're calling at night, all plans have free evening/weekend calling after 7PM, or earlier on some plans. https://shop.koodomobile.com/plans/plans/index.html
Userlevel 4
If you're travelling in Canada, all the plans are canada-wide, so there are never long-distance c...I like the link you put up 😛
If you're travelling in Canada, all the plans are canada-wide, so there are never long-distance c...Yeah... it's not as pretty as yours, though 😛
