Out of country incoming calls
It would be nice if uut of country incoming calls didn't cost extra... should be the same as local incoming calls!...
1 reply
Do you mean when you are traveling out of Canada? That WOULD be nice but not very likely to ever happen... If you are in Canada, calls from anywhere cost the same (free if included in your plan, otherwise your regular cost per minute) 🙂
