My bill is $141.00 .. How can I get it down .. I thinks its data.. not phone or messages. I love using it..please help.
Review your bill, see what the usage is and then go from there. We can't see your bill unless you decide to post a screen shot.
It's actually very easy to get your bill under control, but we need to know a few more things. Tell us what plan you are on, and how many minutes (local and long distance ) you used, how much data you used etc. Then we'll tell you what the best choice is.
