Lost my contacts! Is there a way to export Call Details?
My phone died and with it all my contacts. I was thinking of going thru my old call records to get some of the numbers back. It would be really easy if you could export the call details (to a csv or excel file) but I have only found the PDFs so far Any one have any suggestions on best way to recover contacts or how to export call detail?
you can start by exporting the call details to a PDF file than copy /paste them to an excel file and you would have the data as a table. Let me know if it works.
thanks for your response. i thought of that but the problem is that it only pastes as one cell so you can't sort on the number. so I am not sure i would gain anytime over printing out the last 6 months call details and use a highlighter.
you can also try to paste the call details in notepad or any other text editor. I imagine that the details are delimited with spaces. I mean there is a space between the name and the phone number. After that copy paste to an excel file by using the "Text import wizard" . i hope that will be helpful .
