Long distance question for the Ottawa area
  • 19 November 2018
  • 1 reply
  • 90 views
Hi
I have an 819 phone number with Koodo. For the Ottawa area, it's considered a local number even though Ottawa's prefix is 613.
If I travel down to Brockville, is my 819 number still considered a local number for calls to Ottawa?
Thanks
Kedar
1 reply
That's because Gatineau is 819.
Do you not have canada wide calling?
Also try calling a Brockville number without the 1 and see if it will connect? If it doesnt then it is considered a long distance for you.
