is "Unlimited evenings and weekends" canada-wide?
is "unlimited evenings and weekends" canada-wide? or is it just local?
if it is local is it locally by province or by town/city?
much thanks
It depends on your plan - most plans are Canada-wide and the unlimited weekends will be Canada-wide as well.
If you have a local plan (currently the $25 plan), the unlimited evenings and weekend are local. A local number is any number you can dial without the 1 (one) in front - it varies per town and area 🙂
Unless you ar on the 25 dollar local plan it is nationwide. You'll also know if the plan says Canada wide or something to that effect. When local it I by town/city/region
