Incoming long distance calls
  • 7 May 2019
  • 151 views
I realize I have to have regular minutes to use under my plan, but apart from that, and assuming I have enough minutes, do I get charge LD rates if my relative calls me from England?
I've read all the stuff online but still not quite sure if it means I'm charge LD rates for that incoming call.
Best answer by Dennis 7 May 2019, 23:55
As long as you are in Canada, there are no long distance charges for receiving calls (just like a land line)
Thank you for your speedy reply.
If you are on prepaid, it may be a different story.
With prepaid there still be no long distance charges for receiving calls while in canada
If you are on prepaid, it may be a different story.With prepaid there still be no long distance charges for receiving calls while in canada
Some personal experiences point to the contrary. Numerous examples on this forum can be dug up. Not sure if this was ever properly resolved. Koodo prepaid self-serve not responding at this moment, so can't verify figures.
If prepaid requires an international long distance booster, then this is not suppose to happen. If it does happens, just let us know and we can flag a rep to look into it
