If someone calls me but i dont answer does it use minutes? does voicemail?
  • 18 August 2016
  • 2 replies
  • 11 views
(empty)
Voicemail only uses minutes when you check it from your phone.
If you don't answer the phone, no minutes are used on your end even if the caller leaves a message.
