I have unlimited evenings and weekends (5pm). Why do I have an 'airtime' charge of $23.50 for a 47 minute call after 5pm?
What does it say in your detailed pdf ebill?  Was it an airtime charge?  long distance?
Airtime - long distance overage
Were you calling long distance? To somewhere outside canada?
When calling long distance it uses regular talk minutes and long distance minutes.  It sees as though the regular talk time minutes were not used here (since it is unlimited at this point) but the long distance minutes were charged.
Were you in Canada at the time?  What country were you calling?  Do you have a long distance add-on?  If so which add-on?
The call was from within Canada to within Canada but was long distance. I've got a Canada-wide plan with 500 anytime minutes. There were long distance calls that I made before five later in the billing cycle that weren't charged, so I'm quite confused by this.
What was the area code of the number that you were charged for?
905
Could you take a screenshot of page 3 of your ebill, excluding any personal information, that shows the charges mentioned?
Darren - I see that you made a rate plan change last month and that may have tripped up the way long distance should (or rather should'nt) be charged on your plan. If you shoot us a private message on Facebook, an agent will verify you as the account owner and help look into this.
Thanks gentlemen. I've sent a message through facebook.
