How much will be charged for data overusage?
Userlevel 2
Where can I find the information on how much I will be charged if I go over my data allotment. My plan is Canada wide Data 39 with 600 MB. I've looked under billing and under Plan and add ons. Any hints? Thank you. Sang-gye
Hi there... Here's the info: $5/200 MB
If you log into your account and look under plans and add ons you can roll on your plan and normally it shows everything that's included with it.
Userlevel 2
Thank you very much for the quick response. And how did you find that out? (just for future reference)
Userlevel 2
Hi Chris, yes it shows what's included, but not what overusage costs.
Hmmm...strange. As Robert below showed it on his plan it indicates data overage. Maybe they missed it for thi plan.
