How long are referrals stuck on pending?
  • 29 September 2020
  • 4 replies
  • 43 views
I have one stuck on pending for almost a month now, how long does it normally take for the account to get verified and the status to move to successful? The first bill has been paid and all that.
Thanks.
Best answer by Dennis 29 September 2020, 17:04
It takes 4-8 weeks to process.
but @BicMitchum is also right.  Double check with the person being refered to make sure they went through the process correctly and it they ported their number they used the ported number and not the temporary number assigned.
NOTE: The person being referred only has 30 day since the referral to submit/resubmit
https://buyapowa-embedded-koodo.herokuapp.com/common/rules
I have not encountered a delay (at least, none that I know of) in processing and have never seen a ‘pending’ status. Did you try to re-submit?
https://choosehappy.koodomobile.com/refer/on/
It might actually be because it was done before a number port, I just tried resubmitting.
There you go. Good luck!
