Help
  • 14 April 2021
  • 2 replies
  • 38 views
My phone no. Is 236 333 6018
i have Multiple Sclerosis and find it very hard to change my plan.
sometimes my eyes don’t work, and sometimes my fingers don’t work
would anyone be able to help me to get the cheapest plan...text and calling
right now I  have full data  but I have wifi , so I just want to reduce the exorbitant cost.
Also would I be able to use WhatsApp with the text only plan?
lastly please tell me how to get in touch with Koodo?
Many thanks.
nv
Best answer by Allan M 15 April 2021, 00:05
You can use whatsapp when you're connected to wifi.
If you can't navigate your phone to selfserve to change your plan you can reach out to customer service. Easiest way would be a private message to Koodo through Facebook or Twitter.
You say you have full data, but you want to switch to a minimal plan. So how much data so you need? And what is the budget you have in mind? There might be better options available but it all depends on how much usage you have.
