Fees for incoming US calls on CanTalk300+
Which add on allows me outgoing and incoming calls to and from US if I have Can Talk 300+ mins? In the add on list, I only see reference to outgoing calls to US - nothing about what I'll be charged for incoming.
There are no additional costs to receive calls from the USA while in Canada, so the add on you have found is the one you want.
Incoming calls should be free no matter where they come from. With the Unlimited US add-on that you found you should be able to enjoy all the calling you need to and from the U.S.
Justin Robichaud wrote:
Incoming calls should be free no matter where they come from. With the Unlimited US add-on tha...
Point of order, yer honour! Not FREE, but just use regular minutes. My esteemed colleague one post below should be advised as well. As usual, Dr. dfbutt has the right jurisprudence and interpretation..
Incoming from US will always be free in Canada For outgoing you would need the add-on you mentionned
There is never any free lunch. You have to pay up front for it. Any incoming call from Mars or the moon uses regular minutes on your plan. Apparently outgoing can also use regular plan minutes. You are just avoiding the upcharge for long distance. Your only defense 100% is to have an unlimited plan to begin with. Don't take my word for it.
