charges on incoming calls from USA
are calls that are received from the USA charged the US/min rate
Hi Mary, It depends where you are: If you are in Canada, incoming calls are whatever your rate plan is, even if they are from the other side of the world 🙂 If you are in the USA, you will pay roaming fees for incoming calls.
Sophia wrote:
Hi Mary, It depends where you are: If you are in Canada, incoming calls are whatever your rat...
You don't pay roaming fees for the calls you receive!
