Charged for long distance help plese!!
They charged me 21 bucks for long distance and I think it was because I called a number but I did not know it wasn't toll free... What shuld I do?? Will they take it off my bill if it was a mistake?
It's really up to the agent's discretion but if it was an honest mistake they should take good care of you.
"Toll free" still uses your anytime minutes.(if you don't have unlimited)
I'll try to call them... I was calling a store because they messed up on my order and I thought the number was toll free.... Is there a big chance they will help me or small chance?
Dena Huynh wrote:
I'll try to call them... I was calling a store because they messed up on my order and I thought t...
It's purely at the discretion of the agent. So no promises. Just be polite, respectful, and honest. Yes it was a mistake, but you did honestly make the calls and you are charged correctly for them
I didn't use the toll free number because I thought I was using it but turns out It wasnt.
