Charged for Data while new phone was in the Box - Will Koodo reverse the charge?
Hi, I picked up a new Nexus 4 and got the 30.00 talk and text. The charge for data is outrageous, so I didn't want it. Needless to say the salesperson didn't turn it off while activating the phone, so between leaving the store and getting home, it downloaded 20mb of updates and a Chatelaine magazine. When I saw this, I immediately turned the data off. I've now got a 5.00 data charge on my bill. I know its not huge, but is Koodo customer service resposive to things like this? I've never used them before. Thanks!
Yes, that's what customer service is there for; to help you! Just call *611 from your Koodo phone and explain your situation and they'll most likely be more than happy to reverse it. No guarantee though since it's really no one's responsibility but your own. Also, in then same call, you should request a data block on your account so you cant accidentally incur any data usage.
Hi Ahmad, thanks for that very quick response!! Yes you're right it is my responsibility. Never thought to check it in the store. Lesson learned. I thought about the block, but after poking around here for a bit, it looks like I need to have data on for mms and adjust the apn to block internet usage? Really wish Koodoo had a "reasonable" unlimited data add on as I'd definitely get it. Petro Canada was just 8.00 for unlimited. Thanks again!
Todd Ouellette wrote:
Hi Ahmad, thanks for that very quick response!! Yes you're right it is my responsibility. Never t...
You certainly know your way around here! Yes, that is right about MMS. If you've found the thread(s) with the instructions, proceed! All carriers used to have a $8-$10 unlimited on-device browsing add-on a LONG time ago but they got rid of them because back then they were meant for those dinky 'dumb phones' where really you didnt go on the internet. With smartphones, that's all changed.
Ya, I totally understand. Even Petro and Speakout have dumped their data plans. I'll give Customer Service a call and see what they can do. Thanks for answering my questions!
Userlevel 2
You won't be able to have anything done until your bill comes out. And there's no such thing as an unlimited data addon, never will be.
True I don't have the e-bill yet. Hey even the "unlimited" from Petro was limited 🙂
I don't think adjusting the apn setting will work on the nexus 4. LG phones in general have a tendency to revert back to the default apn settings, and IIRC, the nexus 4 doesn't have a multiple choice option for the apn type, just a text box.
Thanks Timo. Haven't tried it yet but i was going to use the settings from the Chad Burr thread. You're correct, there is no drop down for apn type but you are able to type it in. I'll report back
Ok I tried it . It does work, but when you reboot the phone it reverts back to the original apn. Just make sure to change it. With wifi off, I couldn't load a page in chrome, but was able to send a pic. I think I'll leave data off just to be on the safe side, but at least theres a way to send pics
Are you new to koodo? I actually don't think you will get charged for the data if you are new. When I signed up the rep said that koodo does allow at activation some room for data at no cost for transferring and setting up things. So, it never appeared on my first bill. I don't know what the amount of the allowance is though. Check your first bill.
Yes I am new Chris. I'll check my bill when I get it and report back. That would be great if they do give you some lee way for that.
Just got my first bill today and sure enough there is a charge for 5.00 for Data that occurred between me leaving the store and then taking the phone out of the box and turning the data switch off. Sorry Chris, there is apparently no grace period for new activations. I'm going to call Koodo tomorrow and see if they'll re-bill it and take it off. I know its not a large amount, but i'd really like to get the money back for charges that I didn't even want or willfully incur. I never even touched the phone till I got home. The store associate did all the activation procedures and put it in the box. Apart from their REALLY, REALLY, sucky data plan, the 30.00 a month talk and text plan isn't that bad, especially since 15% goes to paying off the Tab small. I really couldn't do much better with Speakout or Petro-Can, although I like the freedom of being in control of my usage. $5.00 may very well keep me as a customer or see me leave Koodo. I'll report back
Just got my first bill today and sure enough there is a charge for 5.00 for Data that occurred be...
Todd, is the phone under your name? I'd like someone to look at your account as what you describe sounds very strange and want to better understand what may have happened. Thanks for the post!
Hi Jeffrey, Yes the phone is in my name. I just signed up on Sep. 27. I've never had Koodo before. I'm not disputing the charge. It was incurred under my name. The only thing that peeves me, is that I had no idea I was using the data and it was the store that set up my phone.There should be a grace period of some time. I literally drove 15 minutes, opened the box and then when I realized the data was on, I immediately shut the data off. Meanwhile it racked up 20mb (which is a ridiculously small amount, like 15 floppys or so). I don't blame the salesperson as they are busy doing a whole bunch of things to activate the phone. An easy step to miss.
Very strange indeed. All brand new activations should get 10 days unlimited data automatically.
Usually if Koodo can verify that you've only used data upon activation, as in when they were setting it up at the store and you very shortly turned off data or put on a data block they're more than happy to credit you! Like the guys here have said give koodo a call tommorow or if you'tre from BC/AB you can give them a call right now via *611.
Ok that s cool!!! Thanks Joey. I'm in Ontario, so I'll call tomorrrow morning. I just got it tonight. If what you say is true then that would make them #1 in my book 🙂
Wow!! Now that's Customer Service!! I just got an email from Koodo letting me know that they are crediting my account for the 5.00 data charge. I just wanted to thank everyone here for their responses and special thanks to Jeffrey Katz and Ashley at Koodo. I know it wasn't a huge amount, but its refreshing when a company goes above and beyond to help the customer. Koodo definitely came through, I'll certainly be keeping them. Consider this one "resolved". Thanks again!
Wow!! Now that's Customer Service!! I just got an email from Koodo letting me know that they are ...
Appreciate the kind words Todd! We are not quite done just yet though. 🙂 We owe you and the folks here an explanation as things, at least in your case, didn't work as expected. We just didn't want to hold up the credit since we beleived the issue may have been on our end. As soon as I know the details I will let you know what happned. Thanks again for having faith in us! 🙂
An explanation would be great Jeffrey. I know you don't advertise a data "grace" period policy. At least not one that I've seen, but it would be good to know what it is. Some posters have mentioned 10 days, 1 day, during activation, etc.
I think the data grace is something like 10KB or some ridiculously low amount, Todd 🙂 Among many others, the Mobile Masters have been advocating very hard that this is not really 21st Century worthy and would like it see this upped to 5MB or even 10.... and we know Koodo listened (we tied them to a chair and made 'm listen)... we just don't know when/if anything will be done 😃
I agree Sophia, doesn't take much to blow through 10kb. (What is this 1982?) Hopefully they'll get off their old DOS computers and do something
Hey Todd, so we looked at your account and indeed there was an issue. Somehow provisioning (ugly word but nothing better comes to mind) of your newly activated account failed to zero rate the first ten days for data. We looked to see if this is a broader problem. Luckily it wasn't, it was just a one off. I hope that explains things. Thanks for your business and for having faith in us! 🙂
Thanks for the explanation Jeffrey! Hey, These things happen, but more importantly thanks for correcting it. I have to say that I am very happy with Koodo and the service I've received 🙂 Thanks again!!
I had my data blocked with Koodo on my last phone, Nexus S and I really didn't like that. Nothing was ever updated and if I really needed it for a minute or two it I had to telephone Koodo. New phone, Moto G, and I'm a little wiser with the data and the horrible data rates. I turned off all the data on the phone myself, hopped onto Wi-Fi and now that is the only way that I update. You certainly use up a lot of data updating a new phone and this way it is free. No big $ surprises.
